No More Callerid?
I am very puzzled as to why I've suddenly now have no more caller id information coming in. There's no more Pop-Up window, although this has always been turned on. And I've never changed the setting to let 3 rings come in first.
At first I thought maybe it was the Dialogic D/4JCT Card that is faulty. So I switched to using my previous card Proline/2V , and still, no pop up caller id, and the system behaved as if there was no caller id (ie. no matching path found. so stops script/hangs up).
So I tested the same telco line directly with a couple of phone handsets, one old and one new; they both showed the callerid coming in.
I've attached 3 zip'd groups of logs:
One log from Proline/2V: no callerid
One log from D/4JCT: no callerid
One log from D/4JCT from 5 days before this , when caller id being grabbed ok . Maybe you can compare before-and-after system process.
Please advise
EricGuest
EricGuest_withCallerID_4JCTJul27.zip
EricGuest_LostCallerID_4JCT_Aug2.zip
EricGuest_LostCallerIDproline2_Aug2.zip
Can you install VoiceGuide v7 on this system and see if CallerID is detected when v7 is used (with D/41JCT and SR6.0 Drivers).
